Artum_Snowbird
Nov 14, 2016Explorer
When I ran a 32 inch TV from a 400 watt inverter, I had to use the TV on low brightness (which was just fine) or the extra wattage would cause the internal fan in the inverter to come on. I never checked to see what the extra wattage might be to run the fan, likely very minimal compared to the actual load.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
