mikakuja
Nov 16, 2016Explorer
What we have done on our previous TT's... Repeating some of the info already mentioned above...
Our trailers were all 30A service
With the power disconnected from the unit.......
-Transfer switch mounted beside the power center.
-disconnect the main power feed from the main breaker in the control center and feed it into the transfer switch.
-disconnect the 110v side of converter charger from its breaker in the power center and run a length of 14-2 wire from it to the transfer switch. (new single breaker in line between the transfer switch and control center would be recommended).
-connect the shore power and converter charger power into the transfer switch shore input.
-running a new length of 30a wire, connect the transfer switch main out to the control center main breaker.
-now run a 110v line (appropriately sized) from the inverter to the Generator side of the transfer switch.
Everything will now be operational and all outlets in the RV will be powered by either shore or inverter power.
Wired as above the converter charger will only operate on shore power.
The fridge will need to be turned to turned to propane only when using the inverter or it will default to 110v and kill your batteries very quickly. The fridge can be rewired to avoid running it on the inverter if it is wired in the same manor that the converter was (of course using another breaker in line).
A side note; insure you use an appropriately sized fuse and wiring on your inverter, and keep it as close as physically possible to the batteries.
I use 6ft of 0 guage welding cable from the batteries to the inverter with a 150A fuse on our 1500w inverter.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
