SoundGuy
Nov 20, 2016Explorer
pbmazda32 wrote:
thanks for the input. this morning im going to try to isolate all the big stuff and hook it up like mikakaju suggested. i really only need the outlets to work. i put my killowatt meter on my coffee pot and it maxes out at 602w. im going to check out the crock pot next.
the stuff im going to try to isolate and not power is the A/C and charger. the fridge ill just turn to gas. my hpt water tank only runs on gas. what else am i missing?
If you're going to the trouble of turning off your converter and forcing your fridge to gas mode anytime you're running on the inveter there's no need to "isolate" anything. Just don't turn on the A/C, or the microwave, or anything else that would place an excessive draw on the system. Certainly wiring in a transfer switch so you don't have to do this each time is an advantage but it's likewise certainly true that often the K.I.S.S. method works just as well. I myself first fed my trailer "whole house" but when I once forgot to turn off the converter I decided I had a choice to either install a transfer switch to avoid this OR wire in a few dedicated receptacles that are fed directly by the inverter. I chose the latter and it works just fine for my purpose, with no need to do anything but turn the inverter on as needed with the remote switch located inside the camper. Simple. :B
JMO, but you're not being realistic in what you're wanting to power with the inverter & battery :R ... a coffee maker that only takes a few minutes to complete it's task is one thing but powering a crock pot that needs to run continuously for hours makes no sense at all, regardless of it's power rating. Remember, it's not just the power any device is drawing but for how long ... that's why my wife's hair dryer is no problem as she's only running it for just a couple of minutes. The only long duration devices I run are fans but the reason that works is because they draw so little, ~ 30 watts.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
