pbmazda32
Nov 20, 2016Explorer
its in and done. everythings working as it should. found and marked the breaker for the AC. Theyre was a small breaker all the way to the right, flipped it and the charger shut off. so i can flip that off, turn the fridge to gas and im good to go. like i said earlier, my hot water tank is gas only so no need to worry about that. coffee pot ran fine, as did the battery charger for my tools. transfer switch in the inverter worked perfectly. had the inverter running with the tv and roku on, fired up the genny and it flipped over without a blip in anything. thanks for everyones help, its really appreciated.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
