mikestock
Nov 20, 2016Explorer
is this the right product?
https://www.amazon.com/RV750ULHW-Inverter-Charger-Hardwire-Output/dp/B000FTH2R0/ref=pd_sbs_107_t_2?_encoding=UTF8&psc=1&refRID=VRVVZ2D0ES20A5Y5MNER
I'm not positive, but I don't think you want this. If you plan to replace your existing converter/charger, it can be wired to give you the 120 vac you're looking for, but I don't believe this will provide the 12 vdc output you have now. You will have to keep your existing 12 vdc in tact.
I did what you are planning with a 600 watt PSW Xantrex. I just plugged my rv input into the inverter and opened the breaker for the charger. I had 4-6 volt golf cart batteries, so it would last several hours if I was careful about how many lights, tv's, Directv receivers, etc. I used at a time.
Sorry my post didn't make much sense. i forgot to quote the post (on top) i was referring to.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
