CA_Traveler
Apr 06, 2015Explorer III
MagillaGorilla wrote:
Have any of you ever installed an inverter to run your TV and DVD player?
Was it difficult? Depends upon your skill and rig layout.
How many watt did you need? Pure sine wave best and consider 2x the total wattage of your units.
Where did you get the 12VDC power source for the input? Mount as close to the battery as possible. But consider if/how to turn off the inverter.
What tips can you share? The DC amp draw will be about 11x the AC draw. Your xxx watts/120V*11 = your DC amps. Recommend you do a lot of searching on these boards including the archives as you'll need some basic knowledge. Not rocket science but still...
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
