bchoate's avatar
bchoate
DC power issue after installing inverter
Hi everyone, first post here.
This question is in regards to an early 2000s Gulf Stream Seahawk 5th wheel RV.
I've never owned an RV myself, but I've lived in trailer that I gutted and customized with AC power, water, etc.
I was trying to help a friend get AC power to her outlets while off grid, and thought I could just connect an inverter to her battery and then run an extension cord to the shore power plug. What I didn't realize was that there is a DC converter/charger that tries to charge the battery and provides DC power while shore power is connected.
Having hooked it all up and trying it, AC and DC power were now both working, however, after turning the inverter off (after seeing a pretty big voltage drop on the battery due to the charging loop) the DC power no longer works while the inverter isn't running.
I've looked through every panel I can find, and I did locate the main fuse/breaker panel, but all of the fuses were intact, and no breakers were tripped. However, I've tested the blocks where the DC power comes to the panel and it isn't receiving any voltage.
I was able to find one point where the heavy gauge DC wiring terminates (where it connects to the hydraulic pump) and was able to find the expected voltage there, but somewhere between there and the main panel something has burned out or tripped, but I'm not able to find it.
Does anyone know the solution to this, or can you point me in the right direction?
I'm planning to call Gulf Stream tomorrow, but I thought I'd try my luck here in the mean time.
Thanks!
Ben
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
