Muddydogs
Apr 07, 2015Explorer
I just did this install, had a 750 watt inverter laying around so I used it. Put inverter as close to the battery's as I could which is the front storage hold, I mounted it so I could open the door and reach in to the unit to turn it on. For the inverter to battery run I used 4ga wire. For the power line I ran a 10/2 outdoor extension cord under the trailer and up the fridge vent to a plug box hole I cut behind the TV which is mounted above the fridge. Wired a dedicated plug at the TV then ran 10/2 romex behind the microwave and through another cabinet to the DVD player which is above the kitchen sink, on the end of this line I just wired on an extension cord plug to plug the DVD into. System works great but I do have to go outside to turn on and off the inverter, next inverter will have a remote switch.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
