time2roll
Apr 21, 2015Nomad
$1,000 would be insane.
I use a 300w Go Power sine wave inverter with remote switch.
Mounted behind the breaker/fuse panel.
12v power from main battery feed.
Small transfer switch to feed the circuit you want.
No wire to pull, just make connections.
$400 max for easy self install.
Go Power 300w $172
KISAE 15a switch $50
Go Power 300w $172
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
