CA_Traveler
Apr 24, 2015Explorer III
shepstone wrote:That's fine but turn off the charger. With the inverter drawing from the batteries to supply the charger to charge the batteries to supply the inverter doesn't work and will drain the batteries even faster.
For the few rare times that I need to run of the inverter I bring the umbilical to the inverter and plug it in then have hydro to the entire rig. But I've only used it that way for short periods of time. Please tell me if I am doing it wrong. Its a Cat CPL 1000 inverter running off 2 Crown cr235 6volts
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
