MagillaGorilla's avatar
Apr 06, 2015
Power inverter installation
Have any of you ever installed an inverter to run your TV and DVD player?
Was it difficult?
How many watt did you need?
Where did you get the 12VDC power source for the input?
What tips can you share?
  • For just a tv and DVD player, we use a portable 400W pure sine inverter. We have used modified sine wave inverters as low as 200W which also worked just fine but they tend to 'alarm' more frequently due to draw.
    In one tt, there was already a 12V outlet. In a second tt, we added a 12V outlet on the radio wire for one (LR) and a fanatastic fan wire for the other(BR). Both had 15 Amp fuses. It didn't work trying to run the fantastic fan and the inverter with a load at the same time. We also had a third 12V outlet next to our converter with larger wiring for larger loads. In our current class A, there is a 12V outlet in the bedroom which we use at night instead of the power hog 1200W house inverter.
    The advantage of using a portable for that small a load is you can use the outlets for charging phones and such without using the inverter. Our TV and sat receiver or DVD player had a total draw around 100W. YMMV
    Was it difficult? Depends upon your skill and rig layout.
    How many watt did you need? Pure sine wave best and consider 2x the total wattage of your units.
    Where did you get the 12VDC power source for the input? Mount as close to the battery as possible. But consider if/how to turn off the inverter.
    What tips can you share? The DC amp draw will be about 11x the AC draw. Your xxx watts/120V*11 = your DC amps. Recommend you do a lot of searching on these boards including the archives as you'll need some basic knowledge. Not rocket science but still...
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
