westend
May 15, 2015Explorer
The stabilizers and tongue jack are probably wired independent of the rest of the RV. There should also be a wire from the (+) phase terminal on the battery for the emergency break away system. You should be able to remove two wires from the battery to disable the stabilizers and the tongue jack.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
