CA_Traveler
May 14, 2017Explorer III
Try a stud finder. Can you access the roof from inside like a light or speaker hole? If so you will have a better idea of roof construction. You can also run long pieces of aluminum angle that is screwed into beams, etc. Well nuts might also be a good choice for you.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
