dave17352's avatar
dave17352
Explorer II
Mar 09, 2017
solar panel install
I wanted to ask a couple questions on my solar plan. I am looking at ordering one of these 200 watt kits. Renogy 200 watt kit
I plan to put this on my truck camper. I would like to be able to monitor what amps and volts are being put out but the cheapo charge controller doesn't do that. But I am ok with that as long as I don't really need that info.
I plan to install this with the wires running down the back of the fridge and then tying directly into the 12 volt hookup on my Fridge. I think it is 8 gauge wire to the battery. I have a 3 way fridge with the 12 volt option. If I do this I am just going to put the charge controller back there also. Is there any problem with doing this like this?
I am assuming once the panels are hooked up and the controller installed there really should be nothing for me to do except clean the panels occasionally. The charge controller should take care of itself. I can always check things now and then with a multi meter but other than that I would just leave it alone.
So is my plan ok or am I making some big mistakes and wrong assumptions. I am brand new to solar but it is so reasonable now I want to try it out.
Thanks in advance for any help!
Dave
