spoon059
Jun 05, 2015Explorer III
funpilot wrote:rdmike wrote:
Just bought a hw 50. Instructions seem easy enough. Will install Saturday. No detail on what the switch is for on the remote display?
It turns off everything except surge protection. I was told to use it if something went wrong with the unit.
I think it is a generator bypass switch. The EMS will shut down power if there is an open ground. This allows you to "bypass" the open ground fault code when using your generator.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
