2oldman
Mar 18, 2021Explorer II
SJ-Chris wrote:Nice job!
.I could run them in series. This would double the voltage and cut the current in half. My voltage drop % would go from ~3.5% down to ~0.86%.
Yes, series cuts the wire size, the voltage loss and the combiner box. It isn't as big a deal with shade as you might think, provided your panels have bypass diodes. Inverters come in higher voltages too.
For your next install you may want to consider being able to tilt the panels. Makes a big difference in winter.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
