- phaysExplorerCould be as simple as the others say but if you have a detector that activates a solenoid at the tank then you will need to order a special detector with matching solenoid.
- obgrahamExplorer
ScottG wrote:
Agreed. If the old one was hard wired, just use a couple of wire nuts on the new one. 10 minute job if you are not handy.
Probably the simplest repair you can do. Two screws and two wires. - ScottGNomadProbably the simplest repair you can do. Two screws and two wires.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,395 PostsLatest Activity: Nov 08, 2025
