pennstaterv's avatar
pennstaterv
Propane extension
Hello All ---
Been searching around for this topic and there seems to be some conflicting info... so asking for personal experience with tapping into an RV propane line...
My 5er has two 20# propane tanks with the standard auto-switching regulator. I am looking to plumb in at least one outdoor propane line to be used with our griddle and possibly small grill or heater.
I've read about people tee-ing in and successfully doing this, and others who say that the low-pressure output of the regulator will not support an outdoor grill.
From what I can tell, my propane griddle came with a regulator that has an output pressure of 11" W.C. and 95,000 btu.
Thoughts? If possible, I'd like to plumb it in after the RV regulator so I can have the benefit of both propane tanks. I understand I can get an extend-a-stay or what not and plumb in before the regulator, but then I am at the mercy of only one tank.
Thanks!
  • The low pressure hose take off is after the regulator. Camco sells an adapter kit. Remove your BBQ regulator add the Camco valve and quick connect. Suggest Camco because althougb any propane sells hoses and connectors they are not universal. Stick with Camco.
  • i use the extended stay and yes at mercy of one tank but no big deal. It only takes few minutes to switch over to other tank. I use the weber baby q
  • I have 3 taps on mine.
    1 for when I am set up for long stays I have 3 #100 tanks. Cable them up to the rear ladder and run 2 on auto switch over regulators.
    2 & 3 are under side below water heater where I hook up my BBQ.
    All are on 1/2 in. tee's and equipped with shut off valves. BBQ works very well on this set up.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,387 PostsLatest Activity: Sep 03, 2025
