calamus
May 21, 2014Explorer
KD4UPL wrote:
2 regulators in series will result in very low gas pressure and not much fire. You will need to remove the one on the fire pit or connect before the one on the RV. A long hose is no problem. You could go to a welding supply place and they will make you a gas hose as long as you want.
X2 but you can also go to a home depot they will cut ridig pipe for you and you can do all your fitting in black iron pipe.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
