Jerry9n's avatar
Jerry9n
Question on Exterior Door Skin
I have a 1965 Homescraft trailer I am rebuilding. The existing exterior door is shot. It is aluminum skinned white on the exterior and wood paneling on the inside. It has a Jalosie window in it. My question is where do I get a sheet of white anodized aluminum, wrinkle finish for the exterior? Approx 2' X 6'. Have looked through yellow pages and internet. Only other thing I can think of is FRP panel, but it says that they are not UV proof or suitable for wide temp swings (although I know they use some kind of FRP on commercial entrance doors).
Any help on locating a source for the aluminum will be appreciated. I am just west of the Detroit area.
Thanks.
  • Thanks. Perfect. When the snow breaks, I'll take it off and put a piece of plywood on the trailer and take the door to the workshop and rebuild it.
  • I was just looking online trying to remember what I used. I remember the pebbled surface. It could have been the FRP. It held up very well. I bought it at Home Depot.
    It was still in good shape when I sold the TT at least 5 yrs later. I thought I put some pics of it on here but I couldn't find them.
  • Thanks for the ideas. On the plastic panel (FRP I assume) has it held up to the weather? Some of them said they are not UV resistant. Did you paint it?
  • Since you are in SE Michigan try the RV salvage dealers around White Pigeon.
    • Johnson's RV Surplus US12W
    • Tom's Borderline Bargains US131N
    • Bontrager's Surplus US12E
  • I have rebuilt two doors using a plastic like shower lining material from a home improvement store. Back then they were about $35 a sheet. Down side was they are thicker so I had to plane down the entire door thickness to make it fit the metal framing. I use a solid white with a textured finish and they looked great.
  • I got a new garage door a while back and the inside is lined with the same exact kind of material and it's even finished in white.
    I wonder if you could get a piece of scrap material from a place that builds them, or even pay a small fee.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
