RoyB
May 02, 2016Explorer III
I too use the BLUE SEA Terminal blocks (AMAZON) which accepts the same ring terminals used in most RV Battery setups... These also come with a plastic cover that might be needed for your POSTIVE Battery connections in tight places...
These are used alot around multiple RV battery installs...
Using Terminal blocks for multiple connections to different 12VDc loads is a neat way to accomplish routing problems and cleaning up masses of 12VDc cables. I am one that does not like to see more than two ring terminals per connection especially when higher DC currents are involved...
I would be careful however not to introduce different charging length paths from your charging source when feeding multiple batteries. You want each battey in your battery bank to use the same charging path lengths to insure each battery in the bank gets the same charging current when being charged. Otherwise some batteries will charge differently than the others which may result in poor performance and eventually do harm to the battery. This is very important for getting long life out of your battery bank.
Just some of my thoughts
Roy Ken
Roy Ken
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
