4X4Dodger
May 02, 2016Explorer II
Calkidd wrote:
You can use the single post like this....
I know you meant well but this set up is a recipe for disaster or fire.
If the ONE nut comes loose you would have a very bad situation.
The positive cables should be run to a bus bar with each it's own post, secondly they should be fused at about 50 amps.
The post with the Fisheries Supply link is the right way to do this kind of thing...safely and professionally.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
