Calkidd
May 06, 2016Explorer
4X4Dodger wrote:Sorry you feel this way. The nut loosing senario can be played with any situation whereas there is a nut and a post. Any of them can loosen, but that's why they invented lock washers. Additionally, there is only one hot lead coming to this post.Calkidd wrote:
You can use the single post like this....
I know you meant well but this set up is a recipe for disaster or fire.
If the ONE nut comes loose you would have a very bad situation.
The positive cables should be run to a bus bar with each it's own post, secondly they should be fused at about 50 amps.
The post with the Fisheries Supply link is the right way to do this kind of thing...safely and professionally.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
