TNGW1500SE's avatar
TNGW1500SE
Quick Tip on matching "wood"
I've been doing a remodel. I found some laminate flooring a Home Depot that matches my RV perfectly. They also have prefinished moldings that look factory installed. The laminate is hard on your saw blades but looks good. If you need so "wood", check in the flooring dept. They have sample peice.
  • I used Traffic Master laminate flooring which is vinyl. Score with a knife and snap.
  • My friend Rick who is a crackerjack pro carpenter, moved on to construction supervisor. Recently needed to cut a small amount of laminate flooring for an entryway
    . He decided to try his jigsaw and said it worked like a charm! He does have a good Bosch jigsaw.
  • I use a Diablo 60 tooth fine finish blade for Laminate flooring. Its $40.00 at Home Depot. I wont use and of my expensive blades on Laminate.
  • rhagfo wrote:
    What type of blades do you use? I have only used carbide tipped blades for power tools for about 40 years.
    Same as you, carbide. They make blades just for laminate. Get your wallet out if you want one!
    X2. And it also helps to keep your blade depth as shallow as possible to get a cleaner cut. That flooring does wear out a blade quickly so have a few extra blades on hand.
  • rhagfo's avatar
    rhagfo
    Explorer III
  • Sounds like a idea I may look into. Thanks
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
