BarneyS
Nov 16, 2017Nomad
If you can afford it (probably around $5000) I would take a look at RV Armor. It is a sprayed on polyurea coating that is 3/16 inch(187 mils) thick and should provide excellent sound deadening qualities.
Here is another but this one comes to your location to do the work. The cost may be about the same and the application method is different. This one is rolled on and not sprayed.
I have also read about, but have not actually seen any, rigs that have had truck bedliner material sprayed onto their roofs. That may or may not be a cheaper solution than the one above.
Regardless of the product or method, I think the solution to your problem is going to be a sprayed, brushed, or painted on roof coating to help reduce the sound of the rain.
Hope this helps you a bit.
Barney
Barney
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
