MrWizard
Nov 16, 2017Moderator
cannesdo wrote:MrWizard wrote:
This is not a joke
Home Depot , Henry's elastomeric white roof coating #587
$25 gal
Buy 10 gallons
Apply one gal dry for two days, apply the next gal
Use all ten gallons
If the air is dry and the day is warm, you might be able to do the first couple with out the extra dry time
Build up a nice thick layer over the roof
This should help the noise
With a thick layer this coating gets cushy feeling, and will deaden the sound
It's labor and time intensive, but is possibly the least expensive option, and a good one
SUHHHHHWEET! Thanks so much!
roll it easy or brush it, NO hard pressure, you want it fluffy and cushy not flatten like asphalt
and if deemed it necessary, you add extra coats/gallons
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
