GordonThree
Apr 15, 2014Explorer
Radio should have an accessory amp power output wire, that turns on and off with the radio. that output is weak, but it should be enough to run some LEDs.
If not, you could tap into your porch light switch, or the output of the led-strip controller.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
