rp528
Apr 16, 2014Explorer
I'll have to look and see if my stereo has an amp output wire. I bet it just has some rca plugs. It would be to far to run wires all the way to my led light strips. Those are going to be mounted on my frame rails, and im planning on putting a switch in my battery storage box for those. Hopefully ill have time to do a write up when I do it.
I had to cut the speaker holes a little bigger for them to fit. They are tucked right up under my awning, its kind of been a pain in the butt so far. Sure makes me nervous cutting on this thing. I made some gaskets to sandwich between the speakers and exterior wall and then sealed the******out of them with silicone.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
