Colorado__5
May 15, 2019Explorer
Well Roy the bottom line is I'm not getting reception from my antenna. So I don't know if I have to replace it with a newer (Post 2009) BATWING antenna to receive a signal. I have a media switch at the front that would switch the antenna signal from the front tv to the rear tv. This switch board also has a VCR and AUX port for other devices however they are all coax. My blue ray is hdmi and I would need to route that through a coax adapter or run an hdmi cable the length of the rv to watch movies in the rear. I'm curious to know if anyone has ever attempted to route an hdmi cable through the walls of their rv for the rear tv. Does that make better since?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
