davis78
Jul 31, 2019Explorer
philh wrote:
How did you attach the fence post?
I drilled two holes into the frame on each side of the trailer, for each fence post. Then i drilled matching holes into the fence posts. Lastly used a bolt, washers, spacer, and lock nut on each frame hole to attach the fence posts. If you zoom into first picture, you can see the bolts.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
