smkettner wrote:
You don't need 2000 watt inverter to run 200 watts of equipment.
400 watts of solar should make the 2x Honda 2000 about obsolete for battery charging.
If you need to run the air conditioner consider a Magnum or Victron hybrid inverter that will combine power with a single Honda and run the air just fine.
If you don't get the hybrid consider separate components to avoid replacing it all if one part fails.
The reason for the inverter/charger is that I can't locate a separate 100amp charger. If you know of a reasonably priced one I'm all ears. :)
