davidgebo
Jun 16, 2014Explorer
We installed vinyl plank flooring in our 5th wheel, and it worked out great. The planks we used were peel and stick on the edges, about 3/4 inch of sticky adhesive. They stick together in a tongue-and-groove method. And they really stick!! Be sure the planks are properly lined up BEFORE you attach each plank to another. You cannot remove and re-align after they make contact. The planks are heavy and rugged, perfect for an RV, and really easy to put down.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 29, 2025
