rondeb
Oct 07, 2019Explorer
JaxDad wrote:
I wouldn't get too excited about cutting holes in the carpet to get to the bolts, you're going to have to cut a big hole to get the pedestal base out anyway.
Got it out by cutting the carpet in an x pattern from the pedestal to the bolts. You have to get under the RV as the bolts spin until you hold the nuts tight under the RV. 2 of the bolts came up the top and 2 of the bolts come out under the RV, but are so tight up against propane tank that you can't drop them out under the RV so we just cut the bolt shanks that were sticking up into the RV. Pedestal came right out. Ordered carpet tape to repair the carpet as the carpet was cut in an x pattern to allow the carpet to slide over the pedestal so the carpet will just go back down with no filling in carpet. It is definitely a 2 man job One to hold the nuts on the underside and one to unscrew the bolts inside the RV. Now just waiting for the new RecPro recliner to get here.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 19, 2025
