My guess would be the failure of the small diaphragm between the pump housing and the pressure switch has failed. I don't you're going to find parts for that series of pump.
The 2.8 gpm pump should be fine.
No RepliesBe the first to reply
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
