I am installing a tub enclosure on my 2001 jayco qwest. I am told that I need to remove the wall covering before I can glue the enclosure to the wall. The covering is reaaly hard to get off. is this a...
well what happened is I hit the corner of my garage "lightly" and when I lookend in the bathtub i noticed the panel in the corner of it had broken. other than the sheet metal outside there is no other damage i can see. I beleive the corner was bad from previous water damage. thats why got the enclosure. it will hide that corner damage nicely and improve the shower as far as moisture goes. I wonder if I should somehow re-inforce the corner or just glue the enclosure on and move on.?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
