troubledwaters
May 05, 2024Explorer III
So turn the winterizing valve and run the pump, the pink stuff ain’t going to hurt anything (including you). In any event, for the most part the pink stuff should pretty much run out the end of the bypass hose, you can then you can refill it with fresh water, stick the end in a bucket of water, should be good to go then.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 19, 2025
