joelc
Sep 01, 2024Nomad
Not sure, but I think about every 2000 mi. or so. If you have Never Lube Axles or axles that have a zirk fitting be careful how much grease you use, as too much can get on your breaks. Be sure to take the pressure off the wheel by jacking the wheels up so you can spin the wheel and get the weight off.
- StirCrazySep 15, 2024Moderator
its not a case of how much you use in a ezlube axel, its how you put it in, if you squirt it in to fast it can get out of the seals onto the breaks, and if your not spinning the tire as you put it in it could go through the seals. you do want to put lots, the ide is to force the old grease out into the center cup area around the grease nozzle and clean that out. that way you know you have fresh grease through out the barring.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Jan 20, 2026
