JDsdogs
Oct 21, 2024Nomad II
I believe that maintenance should be based on miles traveled as well as time. If you are putting 10,000 miles on a year it's likely you need to repack. That being said, if you roll with about the maximum weight your axles will carry, more often may be necessary. Sadly, while I was researching the purchase of my current TT, I found many trailers being sold that barely had enough axle under them carry them empty.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
