HappyKayakers
Jun 10, 2014Explorer III
Not sure about your model but mine has a rocker switch in one corner of the vent. I set the fan speed one time by standing on a chair, then use a yard stick to hit the rocker switch. That will turn the fan on or off without affecting the vent itself.
If you check out a local big box hardware store, they may have a device that folks use for changing out chandelier or ceiling fan lights. That might work for changing the fan speed.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
