meinook
Jun 15, 2017Explorer
free radical wrote:
I like watching builds of all kinds,,there are quite a few on YT also if you need any ideas..
I would sugest if replacing any plywood use Exterior rated one!!
Next time should any leaks happen it wont get easily rotted..
Good idea. I'm actually thinking of, once the roof, exterior walls and siding are up, spraying the interior with Thompson's water seal before installing wiring, insulation and panels. The wall and ceiling panels will remain bare so if there is a leak they will show it first.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
