westend
Jul 20, 2017Explorer
Ripping good quality studs for 2 x 2's works well.
If I had one piece of advice it would be to draw out mechanical plans. They don't need to be CAD (that does make a neat drawing) but they will help you schedule the installation of wiring, insulation, appliances, etc. It's no fun to rip back out your carefully placed panels or insulation because you forgot the installation of entertainment wire, for example.
I used Eternabond tapes on the roof and I'd advise anyone to do the same if you don't want leaks. The siding I sealed with Geocel Tripolymer sealant. Proflex RV is one of those sealants. After completion, I tested for leaks by pressurizing the interior with a furnace blower.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
