gbopp
Apr 21, 2017Explorer
pianotuna wrote:
If gutting the RV I would go to metal studs. Lighter, stronger and rot proof. Insulate with closed cell foam. I'd use Azdel as much as I could.
Rerun all wires and plan for an upgraded "house" battery bank.
Be sure to do a prewire for solar panels. Use #4 wire.
Excellent advice. I would also replace the water lines while you have the interior gutted.
And, when you get it up and running, you will probably need new tires.
RV tires usually age out before they wear out.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
