Gjac wrote:
2000_Kiwi wrote:
machunt wrote:
how are the vent caps removed?
Mine had four screws securing the cover. I had to cut the screen to gain access to mount the fan.
The screen on mine was held on with screws also but were not visible under the caulking. Once you remove the caulking the screws are visible and can be removed without cutting the screen.
With my roof vent there were only screws for the cover. If I wanted to remove the screen without cutting it I would have had to remove the Dicor sealer and break the seal between the vent and rubber roof. I opted to cut and seal just the screen. I already had the eternabond tape so it made it easy. Time will tell how well it holds up.
Cut Screen
Screen sealed with eternabond tape.
