Gdetrailer
Aug 08, 2015Explorer III
Great idea, similar to my latch which also reuses the existing screw holes in the front opening of the fridge.
The difference with mine it is a slide latch that stays on the fridge between the two doors.
Went to Home Depot and searched for a slide latch the was small enough to fit between the doors then made some shims and a bracket to get the position just right.
latch view
Latch view 2
Latch view 3
Latch view 4
Note, the pop up button is to prevent the slide from moving while traveling. That button was part of an defunct electronic gizmo that was a spring loaded contact. Most likely not needed but I was making sure the doors would not pop open while traveling!
Somewhere if I can find it I have a picture of the latch on the fridge.. but right now I am not sure what folder it is in..
latch view
Latch view 2
Latch view 3
Latch view 4
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
