2006_SMOKEY's avatar
2006_SMOKEY
Refrigerator panels replaced with...
Top panel is a 16 x 20 3/4" semi gloss print of a photo I found on line.
Bottom panel is from AC Moore 18 x 36"print.
  • Those are interesting. I replaced mine with a Samsung 197.
    Dave
  • I placed a white board , the ones that you use an erasable pen to write what we need to do or purchase, I took the two screws on top off and used the panel to measure and cut the new board, placed both both boards back in place and replaced the upper panel and screws, that way I can go back to the original wood look.
    I also installed a white board on the back of the door to the pantry and the cabinet in the bathroom, I marked the shelf's on the one in the pantry and we write what is on that shelf, that way we do not have to take everything out to look for what we want, we cross out what we use and once a month we replenish and redo the list on the board, my wife likes to do lists and spread sheets, me I'm simple what ever is in the can is good to go, I try not to complicate my life.
    navegator
  • For the top panel, I removed the bottom trim (three tiny screws) and slid the panel down and out. I placed the picture over the panel and placed a piece of Plexiglas over the picture and slid it up behind the remaining trim pieces, and reinstalled the bottom trim piece.
    For the bottom panel I did the same only removing the top piece of trim. Took less then 30 minutes. It makes all the difference to the look of the kitchen and I can change them out depending on the season or mood.
  • That looks very good. How did you install them so they don't fall out? Adhesive?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
