doughere
Jan 21, 2018Explorer
releasable pressure sensitive adhesive
This is one, there are many various manufacturers:
https://www.lowes.com/pd/TEC-Gallon-Pail-Trowel-Carpet-and-Sheet-Vinyl-Flooring-Adhesive/4764741
Its a pressure sensitive adhesive that is not designed to form a permanent bond, but will allow the vinyl to be relatively easily removed (or so I am understanding). I've glued sheet vinyl down a number of times, but never used this type of adhesive.
Thinking seriously using, but was hoping to see if someone had tried it!!
Doug
Doug
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 23, 2026
