Clay_L
Jan 18, 2019Explorer
If you don't have one, a staple puller will be a great help. There are several kinds. The one I use is made by Stanley and I bought it at a hardware store. It looks like a flat blade screwdriver with a bent tip. The tip has a V cut in it. A pair of pliers to pull out any staples that break helps also.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
