tnedator
Jun 27, 2017Explorer
rhagfo wrote:tnedator wrote:gbopp wrote:
You can use a heat gun and plastic scraper to remove the old caulk.
There is also a Caulk Remover available.
I just remove the loose caulk. Clean the remaining caulk and apply new over it.
Eternabond will stick to the old caulk. Just clean the area well before applying.
How "delicate" is the rubber roof? I'm just wondering since you recommend using a scraper.
Stated Plastic scraper used with great care.
Sorry, I did see plastic, but didn't repeat it. :)
Do the same instructions apply to TPO?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
