wtmtnhiker
Jun 27, 2017Explorer
ksg5000 wrote:
If you end up tearing the rubber roof suggest you patch with Eternabond. I use a rockwell sonicrafter with special flexible caulk removal blade (http://multifitblades.com/flexible-scraper-blade-271.html).
Got lucky and did not tear the roof but there was a small tear under the old vent already. I caulked it but the tube says it does not fully cure for 30 days so I assume I should wait the 30 days before covering wit eternabond?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
