I bought the 100 watt suitcase back in early February. Mine came with the Anderson connectors. I bought some 10awg cable from Northern Arizona Wind and Sun to make a 15 foot extension. They were out of stock of the 10-12 awg Andersons so I ended up getting the from Battery Mart.
Because of it only giving me 5.7 amps max and hooked up with my fridge going, it only added 4.9 amps per hour. So I bought another 30 watt panel only and it came with the SAE connectors. I cut my loops off and attached the 2 foot section directly to the controller where the other 2 panels attach. Now I can easily add the extra 30 watts that will give me 7 amps.
I did look around for the SAE cable, but only found it with 16 awg wire which is too small for what I wanted.
Have you called them? They have great service and technical support. Start with customer support.
